Shrink-disk collar
May 1, 2010
BLC Bearlok Shrink Disc locks power-transmission components to keyless shafts
BLC Bearlok Shrink Disc locks power-transmission components to keyless shafts more securely than conventional collars.
Features & benefits
  • Balanced for high-speed applications; stronger to withstand wear and abuse
  • Alloy steel, black-oxide coated; bores from 0.75 to 2.50 in., ODs from 1.985 to 1.363 in.; suitable for critical shaft stops and in applications where installation access tangent to the shaft is unavailable
  • Positions and locks cam shafts, conveyor rolls, gears, pulleys, sprockets, and other machine components where exacting adjustment is not required to transmit thrust and torque loads
  • Creates shoulder, eliminating need to machine expensive keyways, splines, shoulders
Whittet-Higgins Co.
(401) 728-0700
www.whittet-higgins.com
Feb. 7, 2025
Feb. 7, 2025
Feb. 7, 2025
Feb. 7, 2025
