BLC Bearlok Shrink Disc locks power-transmission components to keyless shafts more securely than conventional collars.
Features & benefits
Balanced for high-speed applications; stronger to withstand wear and abuse
Alloy steel, black-oxide coated; bores from 0.75 to 2.50 in., ODs from 1.985 to 1.363 in.; suitable for critical shaft stops and in applications where installation access tangent to the shaft is unavailable
Positions and locks cam shafts, conveyor rolls, gears, pulleys, sprockets, and other machine components where exacting adjustment is not required to transmit thrust and torque loads
Creates shoulder, eliminating need to machine expensive keyways, splines, shoulders
Whittet-Higgins Co.
(401) 728-0700
www.whittet-higgins.com
March 18, 2025
March 18, 2025
March 18, 2025
