36-mm linear actuator
Nov. 1, 2011
A new version of the 36-mm G4 linear actuator includes a special Size 14 adapter plate that allows the smaller 36-mm OD unit to replace existing Size 14 hybrid stepper-motor linear actuators.
Features & benefits
  • Lets users easily replace existing hybrid units by using the same bolt pattern and pilot surface; 70 to 260 N force output
  • Optimized tooth geometry and high-energy neodymium magnets deliver 20% higher continuous force output
  • Custom-engineered plastics and larger bearings provide greater rotor support and higher axial load capability
Haydon Kerk Motion Solutions
(203) 756-7441
haydonkerk.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
