Miniature integrated slide and drive
March 1, 2011
Ready-to-install MSC-EL mini-slides with integrated electrical drive reduce the time required to plan, install, and start customized handling systems.
Features & benefits
  • Two sizes available — MSC-EL-12 and MSC-EL-16; can be ordered in standard lengths
  • Capable of travel to any position from 50 to 150 mm; same mounting and cross-section dimensions as pneumatically driven counterpart
  • Brushless, 24-Vdc motor; integrated belt drive gear, ballscrew assembly, lubricated-for-life ball-rail system
  • Maximum load for Size 12 is 4 kg for horizontal motion and 2 kg for vertical; for Size 16, it is 5 kg for horizontal motion and 2.5 kg for vertical
Bosch Rexroth AG
(847) 645-3600
boschrexroth-us.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
