DPG-plus series of sealed two-finger parallel grippers has been extended with sizes 240 and 300 and includes a pneumatic drive with oval pistons.
Features & benefits
Suitable for rough or dirty workpieces, loading and unloading in grinding machines, lathes, milling; painting, powder coating systems, underwater
Sealed grippers rated to IP 67, with moments between 30 and 160 Nm depending on load direction and unit size
Grip forces to 11,700 N; includes multi-tooth guide with round sealing surface of base jaws toward the outside
Schunk Inc.
(800) 772-4865
www.schunk.com
