A line of ceramic balls and stainless-steel, ceramic-hybrid, and full ceramic bearings are now available.
Features & benefits
Ceramic bearings have nonporous, glasslike surface, are virtually frictionless, and require little or no lubrication
Withstand temperatures from -100° to 900° C
Other versions in stainless steel, alumina oxide ceramic, silicon nitride ceramic, and heavy-duty plastics, plus radial deep-groove, thrust, and angular contact bearings
The Boca Bearing Co.
(800) 332-3256
bocabearings.com
