Stack lights
Feb. 1, 2012
Stack lights Werma modular stack light systems from AutomationDirect come in 50 and 70-mm sizes and allow for a combination of optical and audible signal
Werma modular stack light systems from AutomationDirect come in 50 and 70-mm sizes and allow for a combination of optical and audible signal elements.
• Bayonet mechanism lets elements be mechanically and electrically connected within seconds; elements can be changed without tools • Incandescent and LED signal elements in five colors • 70-mm-diameter KS 71 modular system accommodates up to five elements per terminal • Incandescent, LED, and Xenon tube models; select elements are available in various light effects — permanent, blinking, rotating, flashing • 50-mm-diameter KS 50 modular system accommodates up to four elements with either permanent or blinking light effects • Mounting options include wall, base, tube, magnetic, and fold away
(800) 633-0405 / automationdirect.com/stacklights
