Right-angle worm gearboxes
Oct. 14, 2010
NEMA right-angle (RA) worm gearboxes have hollow output shafts that allow for right, left, or dual-shaft configurations
NEMA right-angle (RA) worm gearboxes have hollow output shafts that allow for right, left, or dual-shaft configurations.
Features & benefits
  • 5:1 to 100:1 ratios, 1/15 to 10-hp input, and 5 to 6,000-lb/in. torque
  • 40 to 110-mm sizes; made of high-thermal-capacity die-cast aluminum housings for efficient heat dissipation; powder-coated corrosion-free finish on housings
Groschopp Inc.
(800) 829-4135
groschopp.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
