NEMA right-angle (RA) worm gearboxes have hollow output shafts that allow for right, left, or dual-shaft configurations.
Features & benefits
5:1 to 100:1 ratios, 1/15 to 10-hp input, and 5 to 6,000-lb/in. torque
40 to 110-mm sizes; made of high-thermal-capacity die-cast aluminum housings for efficient heat dissipation; powder-coated corrosion-free finish on housings
Groschopp Inc.
(800) 829-4135
groschopp.com
Aug. 29, 2024
Aug. 28, 2024
