Drives for automation
Feb. 1, 2012
The Z1000 drives from the Drives & Motion Division of Yaskawa America Inc. is comprised of the Z1000 variable speed drive as well as the Z1000 Bypass Package designed specifically for commercial HVAC applications.
• Z1000 for building automation applications through 500 hp; easy-to-read LCD operator with hand-off-auto functions • Internal real-time clock • 5% line impedance reduces input harmonic distortion, while 5-kHz carrier frequency with dynamic noise control quiets motor operation • On-board EMI/RFI filter compliant with IEC 61800-3 minimizes interference • NEMA 1 models include ratings of 3 to 150 hp or 500 hp (480 V); sealed heatsink • Plenum Rated (UL 1995), Seismic Rated (March 2012), and RoHS compliant materials • Intelligent Bypass, when enabled, can transfer the motor across the line when the application requires 60 Hz
(800) 927-5292 / yaskawa.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
