Motor drive power modules
April 1, 2010
The 8B0P passive power-supply modules provide central power for ACOPOSmulti drive systems
The 8B0P passive power-supply modules provide central power for ACOPOSmulti drive systems.
Features & benefits
  • 3 × 380 to 3 × 500 Vac main input voltages provide 8 or 16 kW continuous power and 24 or 48 kW peak power for dynamic applications; passive motor brake prevents hanging loads from dropping if power is lost
  • Motor brake engages if mechanical clamping fails
  • Powerlink network with diagnostics; supply voltage, current, and power data on the dc bus and power-element temperatures are recorded cyclically
  • Integrated power meter function provides information about the machineÍs average and maximum effective and apparent power consumption
B&R Industrial Automation Corp. (770) 772-0400 www.br-automation.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
