ETP shaft-locking bushings ensure higher concentricity than mechanical shaft-locking bushings — even to 0.001-in. TIR.
Features & benefits
Double-walled sleeve encapsulates pressure medium; actuation screw is tightened, expands inner and outer wall uniformly
Suitable for repeated mounting and dismantling
Flange-mounted actuation screws
ETP Express has just one mounting screw positioned in radial location
-22° to 180° F; Classic for 40 to 11,413 ft lb; Express for 40 to 6,400 ft lb
No lubrication
Range of inch and metric sizes in both standard and stainless steel
Zero-Max Inc.
(800) 533-1731
zero-max.com
Dec. 23, 2024
Dec. 23, 2024
