The SWG series of pneumatic angular grippers has added sizes 10 and 12 to its lineup, which now ranges from size 10 to 50. With an opening angle of 15° per finger, and closing and opening times of just a few hundredths of a second, these fast-acting, precise grippers are designed for assembly automation. The low weight of the SWG range (0.11 to 7.51 oz) and the high gripping torque (0.04 to 24.78 lb-in.) enable very high cycles. A spring-loaded grip force safety feature keeps the workpiece securely gripped, even in the event of pressure loss.
Schunk Inc. | www.schunk.com | (800) 772-4865
Jan. 10, 2025
Jan. 10, 2025
