Absolute encoder
May 1, 2010
MAGNETOCODE encoder provides compact angular sensing using Hall sensors
MAGNETOCODE encoder provides compact angular sensing using Hall sensors and multi-turn technology.
Features & benefits
  • 12-bit resolution per turn; 16 turns default; over-range and under-range deadband functionality
  • Operates in -30° to 85 °C, to 125 °C upon request; IP 54 to IP 65 environmental rating; RoHS compliant; no battery needed
  • Blind hollow shaft or synchro flange; cable axial, M12 connector; low cost cable pull adapter for linear measurements; 4 to 20 mA and 0 to 5 V; user-defined output scaling
FRABA Inc.
(609) 750-8705
www.posital.com
March 18, 2025
March 18, 2025
March 18, 2025
March 18, 2025
