Rod-style linear actuators
Dec. 1, 2011
K Series universal rod-style linear actuators offer options for mounting any type of motor.
Features & benefits
  • KT Series incorporates a high-performance precision planetary roller screw; KX Series provides a high-performance planetary roller screw; KM Series delivers the benefits of planetary roller screw technology over ballscrews; KA Series has an Acme screw for low-duty cycle applications with 2.54-mm and 5.08-mm leads
  • Users choose the motor brand and type, including brushless, servo, stepper, dc, or ac motor; input transmission options include parallel motor mounts with belt transmissions — standard ratios of 1:1 to 2:1
  • Optional direct-drive inline mount or base unit without motor-mounting provisions; front or rear flange, rear clevis, rear eye, adjustable side trunnions, end angles, or foot mount; 60-mm frame with standard stroke lengths to 750-mm; longer stroke lengths available
Exlar Corp.
(952) 368-3434
exlar.com
Granite Motion Systems for Precision Automation
Feb. 7, 2025
PI Granite Based Motion Systems. We provide custom Engineered Multi-Axis Precision Automation Systems, built to your specifications– quick turnaround
Feb. 7, 2025
Flexible Multi-axis Granite Motion System for System Integrators and Machine Builders
Feb. 7, 2025
PI’s X-417 multi-axis positioning system / multi-axis stage is a granite motion system for high speed, high precision automation. Preconfigured with a granite base and EtherCat...
Laser Beam Steering Solutions, Fast Steering Mirrors
Feb. 7, 2025
Fast Laser Beam Steering Mirror (FSM) | Piezo Steering Mirrors | Voice Coil | Tip/Tilt Mirrors, Frictionless Flexures, High-Speed Piezoelectric Drives
