Ratchet clutches
Ratchet clutches control motion in several ways — one-way left, one-way right, freewheeling, and fully locked.
Aug. 1, 2011
Features & benefits
  • Clutch body contains only a gear, control lever, and two spring-loaded pawls
  • Moving control lever to the side engages a pawl and permits driving of gear in one direction only; moving it to the other side drives gear in opposite direction
  • Neutral position causes gear to engage with both pawls and prevents it from turning
  • Static torque range is 200 to 6,260 lb-ft, with overrunning speeds of 250 rpm and 30 rpm, respectively
Lowell Corp.
(800) 456-9355
lowellcorp.com
