Plastic-housing bearings
Dec. 1, 2009
Two, three, and four-bolt flange and two-bolt pillow-block-mounted bearings now come with thermoplastic housings
Two, three, and four-bolt flange and two-bolt pillow-block-mounted bearings now come with thermoplastic housings.
Features & benefits
  • Inserts include UHMW with maintenance-free lube strip, cast-nylon, stainless-steel ball bearings, chrome-steel inserts, and other plastics
  • Bearings interchangeable with traditional cast-iron housings; include stainless steel sleeves for shaft protection and positive locking; standard endcaps to prevent contamination
  • Corrosion and moisture-resistant bearings survive washdown; self-lubricating, maintenance-free
Slideways Inc.
(800) 298-7543
www.slideways.com
Circle 166
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
