Energy-isolation valve
March 1, 2011
Corrosion-resistant stainless steel L-O-X energy-isolation valve is designed to withstand washdowns. Features & benefits Valve is lockable only in the
Features & benefits
  • Valve is lockable only in the Off position; large exhaust port for rapid pressure relief; self-draining, Viton seals
  • Port sizes ¼ to 2 in., direct manual operation by a simple push/pull of the handle
  • Pressure-sensing port allows installation of a popup indicator or pressure switch, for visual indication that pressure to the next downstream obstruction has been released
Ross Controls
(248) 764-1800
rosscontrols.com
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
