Rotary position sensors
Dec. 1, 2011
The Vert-X 22E Series of programmable, touchless rotary position sensors use a magnetic pickup that is secured to the rotating object so there is no direct mechanical link between the shaft and measuring system and, therefore, no wear.
Features & benefits
  • Programmable for slope of the linear output, zero and end points, midpoint, and switch steps; eliminate need for other components to specify the angles users want to measure, choose an intermediate plateau, sense of rotation (CW or CCW), V-output function, or switch function
  • Vert-X Easy Adapt lets users program tool with a PC to choose between six modifiable linear output curve characteristics
  • 0 to 360¡ã measurement range, 5 and 24-V supply versions, up to two switch outputs, resolution to 14-bit, ¡Ü0.1¡ã repeatability, and ¡Ü0.1¡ã hysteresis; MTBF is 2.7 or 5.8 million hr, depending on version
  • Output voltage of 10% to 90% of power supply, SPI, and PWM
Novotechnik U. S. Inc.
(508) 485-2244
novotechnik.com/vx22E
March 18, 2025
March 18, 2025
March 18, 2025
March 18, 2025
