Wear-free position sensors
Nov. 1, 2011
Vert-X 22E Series programmable, touchless rotary position sensors use a magnetic pickup that is secured to the rotating object so there is no direct mechanical link between shaft and measuring system.
Features & benefits
  • Programmable for linear output slope, zero and end points, midpoint, and switch steps; eliminates other components to specify angles users want to measure; choose an intermediate plateau, sense of rotation (CW or CCW), V-output function, or switch function
  • Vert-X Easy Adapt lets users program with a PC to choose between six modifiable linear output curve characteristics
  • 0¡ã to 360¡ã measurement range, 5 and 24-V supply versions, up to two switch outputs, resolution to 14-bit, ¡Ü0.1¡ã repeatability and hysteresis; MTBF is 2.7 or 5.8 million hr, depending on version
Novotechnik U.S. Inc.
(508) 485-2244
novotechnik.com/vx22E
