Adjustable Speed Drive
Oct. 1, 2011
Adjustable speed drive allows easy adjustment of application rates — for example, for seed and fertilizer distribution.
Features & benefits
  • Accurate, repeatable speed settings; when used as a prime mover, drive acts as a variable speed device — when used as a secondary drive, it becomes a variable ratio device
  • 0 to 2,000 rpm input, output speed changes; easy adjustments possible with machine on or off
  • Mounts in most positions; handles any input such as chain, belt and couplings; easy to install; no wiring needed
  • Available in standard and custom models and sizes
Zero-Max Inc.
(800) 533-1731
zero-max.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
