Detented shuttle valve
Feb. 1, 2012
The 375 detented shuttle valve from The Lee Co. is for high-pressure applications with system pressures to 5,000 psi.
• 0.375-in.-diameter shuttle valve has a poppet that latches at either seat to close off the emergency port or the normal port • Only 12 gm, the valve is available in a metal seat version, as well as one with a polymeric seat for applications requiring zero leakage
(860) 399-6281 / theleeco.com
Continue Reading
New
Most Read
Sponsored
