Simulink PLC Coder generates IEC 61131 structured text for models that an IDE can deploy to industrial control systems.
Enables model-based design for manufacturing and power-generation equipment controlled by PLCs and PACs; engineers can automatically generate code for industrial controls
Helps eliminate errors associated with hand coding; reduces development and validation time
Source code from Simulink, Stateflow charts, embedded MATLAB code; integrated development environment (IDE) from an industrial automation vendor compiles code to run on controls
Starts at $10,000; third-party modules available from Rockwell Automation and B&R Industrial Automation
The MathWorks Inc.
(508) 647-7000
www.mathworks.com
