Brushless servosystem
The brushless ServoNOW servosystem for single-axis applications limits programmability and uses simple positioning and speed control, reducing overall setup and installation.
Features & benefits
Simplified indexing-type command structure programs all I/O; analog inputs can be selected and set up to control position or velocity
Servomotor with built-in driver, controller, magnetic encoder, and 110/230 Vac universal power supply
Four programmable digital inputs and outputs, analog I/O (0 to 10 Vdc or 4 to 20 mA, 12 bit), and position resolution of 4,096 counts/rev
Five 34-frame models available with variations of high speed (6,900 rpm) and high torque (310 lb-in.)
Bison Gear & Engineering Corp.
(800) 282-4766
bisongear.com
