SLM and SLG rotary actuators are now available with Class I, Division 2 Certification, meeting requirements for use in hazardous environments.
Features & benefits
Includes brushless servomotor and gearmotor technology for high torque-to-size ratio (as in standard models)
Class I, Division 2 option for motion control where flammable gases or vapors may be present
Suited for quarter-turn or multiturn valves or shaft-drive dampers; directly coupled shaft-to-shaft to eliminate cumbersome pneumatic mechanisms
High load bearing; integrated armature and sungear for SLG models; terminal box with NPT ports
SLM: Multiple frame sizes, to 4,000 rpm; SLG Series: 90 and 115-mm frame sizes, and one, two, or three-stack lengths with single and double reductions
Exlar Corp.
(952) 368-3434
exlar.com/product_lines/20-SLM-Series-Motors
