The RW8 gearbox with NEMA-23 input flange features 1:1 to 120:1 ratios, torques to 40 lb-in., and input speeds to 5,000 rpm.
Features & benefits
Gearbox is made from a CNC machined aluminum block housing; dual ball bearings for shaft support
Stainless hardened single-piece worm/input shaft, stainless output shaft
Designed for 24/7 operation
Rino Mechanical Components Inc.
(888) 260-7466
www.rinomechanical.com/gearbox_miniature.htm
