Flexible cable stands up to challenging environments
Aug. 5, 2008
The Olflex Power Multi flexible cable is designed for flexible use and offers STOOW hard service rated cordage for hazardous areas
The Olflex Power Multi flexible cable is designed for flexible use and offers STOOW hard service rated cordage for hazardous areas. The oil resistant cable offers flexible power and control with exposed run approval. Highly crush resistant, the cable complies with the NEC hazardous area standard 501.10 (A) (2) and 501.140 (B) for flexible cables for use in Class I, Division 1 locations. Olflex Power Multi also conforms to RoHS requirements and is one of the only Type TC cables with a wet rating approval as well as cordage approval. It is also UV resistant and approved for direct burial, and is designed for use in all electrical equipment in dry, damp, and wet conditions.
