Perforated belt moves moisture out
Aug. 4, 2008
The 2200 Series conveyor, for light to medium-duty applications, now comes with a perforated bedplate option to better suit cooling and draining applications
The 2200 Series conveyor, for light to medium-duty applications, now comes with a perforated bedplate option to better suit cooling and draining applications. Holes allow air to flow through the conveyor’s frame and bedplate, cooling passing product. For applications that require liquid to be sprayed on passing items, or for items that are damp from a previous process, the holes allow moisture to properly drip through the plastic belt and bedplate without collecting inside the frame. The perforated bedplate option is available on 2200 Series conveyors with a width of at least 12 in.
Dorner Manufacturing
www.dorner.com
(800) 397-8664
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
