TAC 2 Adhesive Chain Lubricant bonds to wear surfaces to reduce friction that causes metal fatigue.
Features & benefits
Contains a tackifier that enables clinging to metal surfaces; inhibits corrosion, reduces load stress, and increases chain life
Withstands up to 350° F, equivalent to many greases, to suit drive chains, open gears, hoists, pulleys, forklifts, rollers, bushings, seals, o-rings, and wire ropes
Low-viscosity formula penetrates and coats vital chain pin and bushing areas; NSF H2 registered for use in meat and poultry plants
CRC Industries
(800) 272-4620
crcindustries.com/ei
