SR22 series Stellar soft starters are a low-cost motor control alternative, but provide smoother control for less torque, shock, and electrical stress than line starters.
Features & benefits
5 to 40-A sizes, overcurrent protected; two DIN-rail mountable frame sizes — 45 and 55 mm
Microprocessor-based starters run from 208 to 460 Vac; configurable, equipped with potentiometers to set start and stop times of up to 30 sec; adjustable start pedestal voltage from 30 to 100%
Suitable for conveyors; thyristors control reduced-voltage starting, stopping; switch to internal contacts for efficiency at rated speed; two-year warranty
AutomationDirect
(800) 633-0405
automationdirect.com
Circle 170
Dec. 23, 2024
Dec. 23, 2024
