Solenoid valves
Sept. 1, 2011
D03 Series zero-leak directional valves are suited for use with most hydraulic pumps to maintain pressure for long periods without replenishing the pressure supply, preventing the hydraulic supply from consuming energy or generating heat.
Features & benefits
  • Poppet-style three and four-way directional-control valves are solenoid actuated and suited for applications with pressures to 5,000 psi (340 bar), where pressure and flow are intermittent
  • Mount to standard valve subplates; 1.93-in. width allows for mounting multiple valves on standard 2.0-in. centers
  • 7075-T651 extruded aluminum bar bodies and hardened and ground-steel poppets and seats
  • Nominal flow rate of 3.0 gpm makes them compatible with most industrial-grade hydraulic fluids; -65° to 225° F operating temperature
Interface Devices Inc.
(800) 539-0193
interfacedevices.com/hydraulic-directional-valve.html
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
