AquaMaKKs LI-SSI Series brakes are specially modified to withstand sea spray and direct seawater splash, providing accurate torque control for constant tensioning in heavy-duty continuous-slip applications.
Features & benefits
Special alloy stainless-steel torque (center) plates are installed along with an engineered friction material designed to run against the stainless-steel torque plate
Three-part-epoxy marine-grade paint, stainless-steel hardware for corrosion protection
Wichita Clutch
Altra Industrial Motion Co.
(815) 389-6227
wichitaclutch.com/productsframe.htm
Jan. 10, 2025
Jan. 10, 2025
