The AEAT-6600-T16 Hall-effect magnetic encoder provides advanced positioning information for use in harsh applications, such as contactless rotary position sensing, robotics, and motor feedback.
Features & benefits
16-bit resolution over 360° and noncontact operation; integrated Hall elements, analog front end, and digital signal processing
Built-in programmability allows customized settings; one-step alignment requires no calibration
Accurate over large axial gap and radial displacement; available in 16-pin TSSOP package; low supply voltage, suitable for portable, battery-operated devices
Simultaneous incremental output of up to 1,024 cycles per revolution; -40° to 125° C operating range
Avago Technologies
(800) 235-0312
avagotech.com
