Rotary actuator
Dec. 1, 2011
The STH servo-driven rotary actuator mounts to nearly all small to medium-duty servomotors.
Features & benefits
  • Planetary gear reducer includes a secondary hollow-bore rotary stage; STH for 12:1 to 324:1; cross roller bearings within rotary stage allow for thrust loads to 800 lb
  • Offset 85-mm hollow bore allows wiring, tubing, and ballscrew to pass through — suitable for small to medium indexing tables, robot end-effectors, dispensing assemblies, and automated assembly equipment
Shimpo Drives Inc.
(800) 842-1479
shimpodrives.com
