Safe plugs and receptacles
April 1, 2012
DSDC Series dc-rated plugs and receptacles from Meltric Corp. maximize safety, performance, and durability.
• Standard padlockable pawl feature (with lockout hole) enables locking in connected or disconnected mode • Thumbscrew locking feature on DSDC2 models helps prevent unintended disconnection under load; dead front safety shutter prevents user access to live parts • Jumpers provided on 600 and 750 Vdc models as a safety precaution to split the arc in case of accidental disconnection under load • Spring-loaded butt-style contacts ensure optimal contact force over thousands of operations • Suitable for solar power farms, wind farm power distribution, data centers, and industrial facilities (battery charging, lifting magnets, and dc motor connections)
(800) 433.7642 µ meltric.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
