POSITAPE stainless-steel tape position sensors include the WB10ZG series that offers a 6.5 ft. measurement range in a 2 × 2 × 3.3 in. housing.
Features & benefits
Tape is taken up on precision-machined drum
Flexible for long life; suited to applications where pulleys are required due to space constraints that prevent direct inline measurement
Flat, smooth tape surface allows for quick removal of ice accumulation
Standard tape brush continuously wipes surface to remove debris
Enclosure rating of IP65 (IP67 with mating connector); available with 0.5 to 4.5 V, 0.5 to 10 V, and 4 to 20 mA analog outputs or SSI, CANopen, CAN SAE J1939 digital outputs
ASM Sensors Inc.
(630) 832-3202
asmsensors.com
March 18, 2025
March 18, 2025
March 18, 2025
