Roller and engineered chains
Nov. 20, 2012
An extensive range of roller and engineered chains meet the demanding requirements of power-transmission and conveyor applications in the food and beverage, mining and cement, and steel industries, among others.
Transmission, or roller, chains with ¼ to 3-in. pitch sizes feature through-hardened, shot-peened, and ballburnished inner and outer link plates with wide waist; case-hardened precision-ground pins; precision cold-rolled bushings; and through-hardened, shot-peened solid rollers, providing increased fatigue strength, higher resistance to damage from shock loads, maximum wear resistance, and extended service life.
The chains perform in –4 to 300°F (stainless-steel versions in –4 to 750°F) and can be supplied with rivet or cottered design. Nonstainless types are prelubricated.
SKF USA Inc.
890 Forty Foot Rd.
Lansdale, PA 19446
(267)436-6693
© 2012 Penton Media, Inc.
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
