Linear actuator for food-grade applications
Nov. 6, 2012
The stainless-steel Hygienic Green Drive linear actuator is suitable for food-grade applications as well as clean-room environments. The actuator comes with a 16 or 25-mm-diameter shaft
The stainless-steel Hygienic Green Drive linear actuator is suitable for food-grade applications as well as clean-room environments. The actuator comes with a 16 or 25-mm-diameter shaft. Available with a variety of coil windings, it features rated forces between 8.4 and 96.1 N, acceleration forces (peak force) from 33.7 and 384.5 N, and rated currents between 0.53 and 1.85 A. The Drive offers built-in feedback electronics, including position sensors, interpolation electronics, and temperature sensors.
Nippon Pulse America Inc.
4 Corporate Dr.
Radford, VA 24141
(540) 633-1677
www.nipponpulse.com
© 2012 Penton Media, Inc.
