High-force linear actuator
The High Force Linear Actuator Model LA100-93-000A packs a 500-lb peak force — a level that typically requires two actuators — and a continuous force of 292 lb with 2-in. total stroke. The device features a semihoused construction with built-in shaft and bushings that orient the coil assembly concentric to the field assembly, which makes actuator mounting fast and easy. The unit measures 10 in. in diameter and 9.3 in. long at mid stroke.
BEI Kimco Magnetics
1499 Poinsettia Ave., Suite 160
Vista, CA 92081
(800) 572-7560
www.beikimco.com
