Positioning system
Oct. 16, 2012
The S2 Servo Pneumatic Proportional Control System is for variable positioning of air cylinders. The all-in-one pneumatic device can positioning heavy loads at speeds up to 100 ips. Handling loads in excess of 100 lb, it can move at 25 ips across a selection of cylinders
The S2 Servo Pneumatic Proportional Control System is for variable positioning of air cylinders. The all-in-one pneumatic device can positioning heavy loads at speeds up to 100 ips. Handling loads in excess of 100 lb, it can move at 25 ips across a selection of cylinders.
The unit’s controller eliminates external wiring between the valve and electronics. A single five-pin M8x1 connector lets a single cable carry all signals to the electrical cabinet. The unit features 10-Vdc excitation for resistive linear feedback devices.
Enfield Technologies
35 Nutmeg Dr.
Trumbull, CT 06611
(800) 504-3334
www.enfieldtech.com
© 2012 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
