Pneumatic stopper cylinders
Oct. 16, 2012
Stopper cylinders are available in seven rodend styles with strokes of 20 and 30 mm and in 32, 40, and 50-mm bores. Shock absorbers are standard on lever/roller-style models; direction of rollers is adjustable
Stopper cylinders are available in seven rodend styles with strokes of 20 and 30 mm and in 32, 40, and 50-mm bores. Shock absorbers are standard on lever/roller-style models; direction of rollers is adjustable. All styles feature magnetic pistons so magnetic sensors can be mounted on cylinder surfaces when input signals are required for controllers. The device’s extruded aluminum body has counterbored through holes for rigid mounting in limited space. Units can be double acting or single acting with spring extended rod. The double-acting models are available with a built-in failsafe extended rod.
Fabco-Air Inc.
3716 N.˜E. 49th Ave
Gainesville, FL 32609
(352) 373-3578
www.fabco-air.com
© 2012 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
