Customized plastic tubing
Oct. 16, 2012
Custom extrusions – additives are blended with raw materials for lowtemperature flexibility, improved elasticity, and antistatic properties
Eight methods to customizing plastic tubing are now available.
Custom extrusions – additives are blended with raw materials for lowtemperature flexibility, improved elasticity, and antistatic properties.
Hot Bond thermally bonded tubing – a neat, contained ribbon of tubing without the use of damaging adhesives or cable ties.
Heat-formed shapes – eliminate problems such as kinking and proper fitting attachment.
Coiling – gives traditionally straight or semirigid tubing easy movement and retraction. Fabrication – printing, striping, repetitive cutting, slitting, and hole punching
Overbraiding and jacketing – offers heat and friction protection, plus added pressure capabilities
Hose assemblies – reduces on-site inventories and labor
Dip-molded tubing – provides consistent interior dimensions, even flow, and the elimination of fittings and clamps
NewAge Industries Inc.
145 James Way
Southampton, PA 18966
(800) 506-3924
www.newageindustries.com/custfab.asp
© 2012 Penton Media, Inc.
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
