The new PX5200 Series of rangeable wet/wet differential pressure transmitters features a backlit display for easy reading (rotates in 90° increments to fit the location); stainless-steel, FKM, and ceramic wetted parts; flow measurement totalization/square-root extraction function; program-lock function; and quick ranging with internal pushbuttons. Housed in a rugged aluminum NEMA-4X (IP65) enclosure, the transmitter is suitable for flow and tank-level applications where low dP measurements are required.
Omega Engineering Inc.
One Omega Dr.
Stamford, CT 06907
(800) 826-6342
www.omega.com/pptst/PX5200.html
