Pressure-relief valve
Sept. 21, 2012
The new Hi-Q pressure-relief valve provides both high-relief pressure and high flow rate.
The new Hi-Q pressure-relief valve provides both high-relief pressure and high flow rate. This valve, capable of relief pressures up to 5,400 psid and flow rates over 19 gpm, uses a side inlet flow path to minimize the installation boss size and weight.
The valve comes in a range of cracking pressures from 1,000 to 5,400 psid, and is designed for nominal pressures up to 5,000 psi and peak pressures up to 6,750 psi.
The Lee Co.
2 Pettipaug Rd., Box 424
Westbrook, CT 06498
(860) 399-6281
© 2012 Penton Media, Inc.
