Right-angle gearhead
The 22 and 32-mm right-angle gearheads provide an adjustable 360° right-angle output. The compact, lightweight and high-torque gearheads feature Spiroid technology that offer performance benefits, including extremely high torque transmission; high stiffness/low deflection with large applied loads; back-drivable (4:1 ratio) and nonback- drivable (31:1 ratio) versions; absolute output shaft position achievable with encoder mounting option; low backlash; and up to 3:1 contact ratio.
The gearheads may be mounted directly onto brushed/brushless motors or stacked on different ratios of the company’s GP22 and GP32 planetary gearheads.
maxon precision motors inc.
101 Waldron Rd.
Fall River, MA 02720
(508) 677-0520
