Double-bush bearing
Sept. 21, 2012
A double-bush bearing provides high performance for V-drive transmissions while requiring less space.
A double-bush bearing provides high performance for V-drive transmissions while requiring less space. The bearing is tailored to withstand pressure as well as tensile load. A rubber coating on the vertical, upper side insulates the drive assembly from upward moving vertical forces. The double-bush bearing ensures that stiffness remains low even under the load caused by the V-drive transmission, providing sustained low-resonant frequency sdamping.
ContiTech North America Inc.
136 Summit Ave.
Montvale, NJ 07645
(800) 654-0974
© 2012 Penton Media, Inc.
