Rotary module
Sept. 6, 2012
The compact ERS rotary module, with a center hole for cable feedthrough, is multifunctional and can be used as a freely programmable rotary indexing table; workpiece support for laserwelding machines, or an axis of rotation for grippers in gantries.
The compact ERS rotary module, with a center hole for cable feedthrough, is multifunctional and can be used as a freely programmable rotary indexing table; workpiece support for laserwelding machines, or an axis of rotation for grippers in gantries. Any intermediate position can be approached at a repeat accuracy of 0.02°.
The module comes in three sizes with diameters of 135, 170, and 210 mm. Size 170 measures 66 mm in height and achieves 5-Nm torque. An optional pneumatic holding brake ensures that individual positions can be reliably fixed.
The core of the module is a torque motor with a hollow shaft, which allows the module to be lightweight, more compact, wear-free, and extremely reliable. In contrast to rotary modules with conventional servomotors, the module has no additional interfering contours.
Schunk
211 Kitty Hawk Dr.
Morrisville, NC 27560
(800) 772-4865
www.schunk.com
© 2012 Penton Media, Inc.
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
