The right-angle NEMA gearbox is designed to IP65 specifications for use in wash-down applications in packaging equipment and similar machinery. The NEMA-34 flanged gearbox features backlash rated at 30 arc-min with options for 4 or 8arc-min; 440C stainless-steel bearings with seals and nitrile O-ring shaft seals on both input and output; all stainlesssteel fasteners; and a hard-anodized aluminum or 316 stainless housing.
Ondrives.US Corp.
216 North Main St.
Freeport, NY 11520
(888) 260-7466
