PTFE/FEP flared tubing
Aug. 23, 2012
Flared tubing products resist chemicals in harsh environments and perform at elevated temperatures.
Flared tubing products resist chemicals in harsh environments and perform at elevated temperatures. The tubing eliminates the need for additional tooling and flanging supplies. Flares are available in many styles and each tube is customized to fit the application. The tubing is 100% traceable from the resin to the finished product. Sizes range from 0.005/0.127 mm ID up to 4-in. OD, with wall thicknesses ranging between 0.010 in. (0.32 mm) up to 0.090 in. (2.28 mm), depending on size.
Parflex Div./TexLoc
Parker Hannifin Corp.
4700 Lone Star Blvd.
Ft. Worth, TX 76106
(800) 423-6551
© 2012 Penton Media, Inc.
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
