Power-distribution connections
Aug. 9, 2012
Powerfast connectivity products are designed to replace expensive, timeconsuming hardwiring methods.
Powerfast connectivity products are designed to replace expensive, timeconsuming hardwiring methods. A full line of cordsets, receptacles, reducers, reducer tees, field wireables, rotary disconnect switches, and power-lock devices let users configure custom power-distribution systems.
The UL-approved devices are available in A-Size (“7/8” in.), D-Size (1 3•/8” in.), M16, M23, and M40 and are rated for up to 40 A. powerfast products can be used in multiple devices, including motors, lights, heaters, and other electrical devices.
Turck Inc.
3000 Campus Dr.
Plymouth, MN 55441
(800) 544-7769
© 2012 Penton Media, Inc.
